Administrator Command
Introduction
: Guide Structure
Guide Structure
The Administrator Command Reference Manual is divided into the following sections:
Stand-Alone DICE
applies to Standard and Global projects and describes how to run the AVEVA E3D™ Data Integrity Checker, DICE, from outside AVEVA E3D™. This chapter is included in the Command Reference manual as there is no interface to stand-alone DICE, and you will need to enter commands interactively or via a macro.
Reconfiguration
applies to Standard and Global projects and describes database reconfiguration.
System and Global Projects
applies to Standard and Global projects. It contains maps of the System Database and Global Database Hierarchies, and a list of the ADMIN elements and their attributes that can be set explicitly by the user.
Transaction Database
applies to Global projects only, and describes the transaction database, the elements in it, and their attributes.
Command Summary
applies to Standard and Global projects. It lists the ADMIN commands in functional groups.
Command Details
applies to Standard and Global projects. It occupies the majority of the manual and describes every ADMIN command. The descriptions appear in alphabetical order of command names.
Dabacon Buffer Size
specifies buffer requirements for running a project.
Drawing File Name and Folders
file name conventions used for Drawing and Picture files during propagation.
