Using AVEVA E3D™ Administration for a standard (non-global) project is described in Project Administration in the Administrator User Guide, which tells you how to set up and administer AVEVA E3D™ projects using the GUI. The User Guide also describes the concepts that AVEVA E3D™ System Administrators need to understand.
Using Plant Design Global via the GUI is described in the Overview of Global, which also describes the concepts in Plant Design Global that AVEVA E3D™ System Administrators need to understand.
