AddService(Type,Object,Boolean) Method
Adds the specified service to the service container, and optionally promotes the service to any parent service containers.
[Obsolete("Use the DependencyResolver instead")] public abstract void AddService( Type serviceType, object service, bool promoteToParent )
[Obsolete("Use the DependencyResolver instead")] public: abstract void AddService( Type^ serviceType, Object^ service, bool promoteToParent )
- serviceType
- The type of service to add.
- service
- An instance of the service type to add. This object must implement or inherit from the type indicated by the serviceType parameter.
- promoteToParent
- true to promote this request to any parent service containers; otherwise, false.
