Aveva.ApplicationFramework Namespace (Aveva.ApplicationFramework)
Classes
| Class | Description | |
![]() | Addin | Class to represent an ApplicationFramework Addin |
![]() | AddinEventArgs | Class used to hold the event arguments in Addin related events, single addin |
![]() | AddinManager | Provides properties and methods for the management of ApplicationFramework Addins. |
![]() | AddinsCollection | Class to represent the collection of loaded ApplicationFramework Addins |
![]() | AddinsEventArgs | Class used to hold the event arguments in Addin related events, multiple addins |
![]() | AllowedValues | Allowed values class |
![]() | BaseConfigurationProvider<TS> | Base provider class (keep for backwards compatibility) |
![]() | BaseConfigurationProviderV2<TS> | Base provider class |
![]() | Configuration<T> | Configuration |
![]() | ConfigurationCollection<T> | Collection of configurations |
![]() | ConfigurationConstituents | Class for splitting a fully qualified key into its constituent parts. |
![]() | ConfigurationDisplay<T> | Configuration Display |
![]() | ConfigurationDisplayValidStrings | Configuration Display for valid string values |
![]() | ConfigurationDisplayValidStrings.ValidStringsDisplay | Class for converting objects to displayable strings. Have to inherit from StringConverter rather than TypeConverter, otherwise GetStandardValuesExclusive isn't called and the list isn't editable when appropriate. |
![]() | ConfigurationEventArgs | Used as a container to pass the key and provider for the added/removed configuration |
![]() | ConfigurationGroup | configurationGroup object |
![]() | ConfigurationTrail | Configuration Trail |
![]() | ConfigurationTrailLink | Configuration Trail Link |
![]() | ConfigurationTrailPropertyDescriptor | Configuration Trail PropertyDescriptor |
![]() | ConfigurationUtils | Configuration utilities |
![]() | ConfigurationValue<T> | Configuration value |
![]() | ConfigurationValueArrayDisplay<T> | Configuration Display |
![]() | ConfigurationValueDisplay<T> | Configuration Display |
![]() | ConfigurationValueDisplayBase<T> | Base class for Configuration Value Display |
![]() | ConfigurationValueDisplayStandard<T> | Configuration Display |
![]() | ConfigurationValueEnumDisplay | Configuration configuration |
![]() | ConfigurationValueEnumDisplayBase | Base class for Configuration Enum Display |
![]() | ConfigurationValueEnumDisplayBase.EnumDisplay | Class for converting objects to displayable strings |
![]() | DependencyResolver | Static Gateway to resolve dependencies cleanly |
![]() | Diagnostics | Class with static methods to display process metrics |
![]() | DoubleRange | Represents a minimum/maximum range of doubles |
![]() | ElapseTimer | |
![]() | ElementListEventArgs | Element List EventArgs |
![]() | EnumCollection | Enumeration Collection |
![]() | IntegerRange | Represents a minimum/maximum range of integers |
![]() | InterfaceResolutionException | Exception when interface not found |
![]() | Log | Static gateway for logging |
![]() | LogToNull | A log to null. |
![]() | LogViewer | Optionally buffered log viewer |
![]() | RangeBase<T> | Range base generic class |
![]() | ServiceEventArgs | Class used to hold the event arguments in SeviceManager related events |
![]() | ServiceManager | Provides a means by which the various components of the ApplicationFramework (e.g. Presentation Component) can publish their services. The ServiceManager also acts as a service provider responding to requests for services. THIS CLASS IS OBSOLETE use the DependencyResolver instead |
![]() | SettingsGroup | Class that represents a named collection of keyed objects which represent application settings |
![]() | SettingsGroupsCollection | A collection of SettingsGroup objects |
![]() | SettingsManager | Class to manage application settings |
![]() | StringValidValue | Class representing a list of allowable string values |
Interfaces
| Interface | Description | |
![]() | IAddin | Interface which enables communication between the framework and the addin. |
![]() | IAddinInjected | Interface which enables communication between the framework and the addin., uses dependency injection |
![]() | IAddinManager | Provides properties and methods for the management of ApplicationFramework Addins. |
![]() | IAddinModifiesElements | Addins that modify elements |
![]() | IAddinTty | Interface which enables communication between the framework and the addin in tty. |
![]() | IAddinTtyInjected | Interface which enables communication between the framework and the addin in tty., uses dependency injection |
![]() | IAllowedValue | Interface for allowed values |
![]() | IApplicationParam | Interface for Event param |
![]() | IConfiguration<T> | Covariant interface |
![]() | IConfigurationBase | Configuration setting interface |
![]() | IConfigurationCollection<T> | Collection Configuration interface A collection of values to return as a collection |
![]() | IConfigurationGroup | Configuration Group interface A Group is a specific collection of groups and configurations. |
![]() | IConfigurationManagerConsumer | Configuration Manager Consumer Interface |
![]() | IConfigurationProvider | ConfigurationProvider Interface |
![]() | IConfigurationProviderBase | Configuration Provider base interface |
![]() | IConfigurationTrial | Configuration Trail |
![]() | IConfigurationValue<T> | Configuration value interface, typed |
![]() | IConfigurationValueBase | Configuration value interface |
![]() | IConfigurationValueDisplay | Configuration Display interface |
![]() | IDependencyContainer | Dependency Container Interface |
![]() | IDependencyManager | Dependency Manager Interface |
![]() | IDependencyResolver | Dependency Resolver Interface |
![]() | IEventAggregator | Intrface for EventAggregator |
![]() | ILog | Logging interface |
![]() | IServiceManager | Interface for Service Manager THIS INTERFACE IS OBSOLETE use the DependencyResolver instead |
![]() | ISettingsManager | Interface to class for managing application settings |
Delegates
| Delegate | Description | |
![]() | AddinEventHandler | Represents the method that will handle addin related events. |
![]() | ServiceEventHandler | Represents the method that will handle service related events. |
Enumerations
| Enumeration | Description | |
![]() | AllowedValueType | The type of allowed values |
