TransitionType_UserDefined Class
            This class allows you to create user-defined transition types. You specify these
            as a list of TransitionElements. Each of these defines:
            End time , End value, Interpolation method
            For example, say you want to make a bouncing effect with a decay:
            EndTime%    EndValue%   Interpolation
            50          100         Acceleration
            75          50          Deceleration
            85          100         Acceleration
            91          75          Deceleration
            95          100         Acceleration
            98          90          Deceleration
            100         100         Acceleration
            The time values are expressed as a percentage of the overall transition time. This
            means that you can create a user-defined transition-type and then use it for transitions
            of different lengths.
            The values are percentages of the values between the start and end values of the properties
            being animated in the transitions. 0% is the start value and 100% is the end value.
            The interpolation is one of the values from the InterpolationMethod enum.
            So the example above accelerates to the destination (as if under gravity) by
            t=50%, then bounces back up to half the initial height by t=75%, slowing down
            (as if against gravity) before falling down again and bouncing to decreasing
            heights each time.
public class TransitionType_UserDefined : ITransitionType
public ref class TransitionType_UserDefined : public ITransitionType
Inheritance Hierarchy
System.Object
   Aveva.ApplicationFramework.Presentation.Utilities.Transitions.TransitionType_UserDefined
      Aveva.ApplicationFramework.Presentation.Utilities.Transitions.TransitionType_Bounce
      Aveva.ApplicationFramework.Presentation.Utilities.Transitions.TransitionType_Flash
      Aveva.ApplicationFramework.Presentation.Utilities.Transitions.TransitionType_ThrowAndCatch
