ToolTreeNode Class Methods
For a list of all members of this type, see ToolTreeNode members.
![]() | AcceptDrop | Overridden. Accept drop and action it if appropriate. |
![]() | ActivateCell | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | BeginCellEdit | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | BeginEdit | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | BringCellIntoView | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | BringIntoView | Overloaded. (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | BringLabelIntoView | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | CancelUpdate | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | Clone | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | CollapseAll | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | CreateObjRef | (Inherited from System.MarshalByRefObject) |
![]() | Detach | Detaches this Aveva.ApplicationFramework.Presentation.Customize.AvevaTreeNode. (Inherited from Aveva.ApplicationFramework.Presentation.Customize.AvevaTreeNode) |
![]() | Dispose | Overridden. Performs application-defined tasks associated with freeing, releasing, or resetting unmanaged resources. |
![]() | EndCellEdit | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | EndEdit | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | ExpandAll | Overloaded. (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | GetCellText | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | GetCellValue | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | GetDropPosition | Gets drop position. (Inherited from Aveva.ApplicationFramework.Presentation.Customize.AvevaTreeNode) |
![]() | GetLifetimeService | (Inherited from System.MarshalByRefObject) |
![]() | GetNodeCount | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | GetSibling | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | HasSibling | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | InitializeLifetimeService | (Inherited from System.MarshalByRefObject) |
![]() | InsertNode | Overridden. Inserts a node. |
![]() | IsAncestorOf | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | IsValidDropTarget | Overridden. Check if the given node and tool is valid as a drop. |
![]() | NotifyPropChange | Overloaded. (Inherited from Infragistics.Shared.SubObjectBase) |
![]() | Remove | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | Reposition | Overloaded. (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | ResetAllowCellEdit | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | ResetCheckedState | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | ResetEnabled | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | ResetKey | (Inherited from Infragistics.Shared.KeyedSubObjectBase) |
![]() | ResetLeftImages | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | ResetLeftImagesAlignment | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | ResetNotificationBadgeText | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | ResetOverride | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | ResetRightImages | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | ResetRightImagesAlignment | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | ResetSelected | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | ResetText | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | ResetVisible | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | ResolveAppearance | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | ResolveLabelEditAppearance | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | SetCellValue | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | ShouldSerializeCheckedState | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | ShouldSerializeDataKey | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | ShouldSerializeEnabled | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | ShouldSerializeKey | (Inherited from Infragistics.Shared.KeyedSubObjectBase) |
![]() | ShouldSerializeLeftImages | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | ShouldSerializeLeftImagesAlignment | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | ShouldSerializeRightImages | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | ShouldSerializeRightImagesAlignment | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | ShouldSerializeSelected | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | ShouldSerializeTag | (Inherited from Infragistics.Shared.SubObjectBase) |
![]() | ShouldSerializeText | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | ShouldSerializeVisible | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | Toggle | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | ToString | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | Update | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | VerifyNotDisposed | (Inherited from Infragistics.Shared.DisposableObject) |
Protected Methods
![]() | ContainsTool | Overloaded. Overridden. Check if target contains tool. |
![]() | DeserializeTag | Overloaded. (Inherited from Infragistics.Shared.SubObjectBase) |
![]() | GetNotificationBadgeBounds | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | GetObjectData | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | InitializeTag | (Inherited from Infragistics.Shared.SubObjectBase) |
![]() | MemberwiseClone | Overloaded. (Inherited from System.MarshalByRefObject) |
![]() | OnAddedToCollection | (Inherited from Infragistics.Shared.KeyedSubObjectBase) |
![]() | OnDeserialization | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | OnDispose | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | OnObjectPropChanged | (Inherited from Infragistics.Shared.SubObjectBase) |
![]() | OnRemovedFromCollection | (Inherited from Infragistics.Shared.KeyedSubObjectBase) |
![]() | OnSubObjectPropChanged | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | RemoveChildNode | Overridden. Removes the child node described by treeNode. |
![]() | ResetDataKey | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | ResetInternedKey | (Inherited from Infragistics.Shared.KeyedSubObjectBase) |
![]() | ResetTag | (Inherited from Infragistics.Shared.SubObjectBase) |
![]() | SerializeTag | Overloaded. (Inherited from Infragistics.Shared.SubObjectBase) |
![]() | ShouldSerializeAllowCellEdit | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
![]() | ShouldSerializeOverride | (Inherited from Infragistics.Win.UltraWinTree.UltraTreeNode) |
