EditValue(ITypeDescriptorContext,IServiceProvider,Object) Method
- context
- An System.ComponentModel.ITypeDescriptorContext that can be used to gain additional context information.
- provider
- An System.IServiceProvider that this editor can use to obtain services.
- value
- The object to edit.
The new value of the object. If the value of the object has not changed, this should return the same object it was passed.
