GetEditStyle(ITypeDescriptorContext) Method
Gets the editor style used by the System.Drawing.Design.UITypeEditor.EditValue(System.IServiceProvider,System.Object) method.
public override UITypeEditorEditStyle GetEditStyle( ITypeDescriptorContext context )
public: UITypeEditorEditStyle GetEditStyle( ITypeDescriptorContext^ context ) override
- context
 - An System.ComponentModel.ITypeDescriptorContext that can be used to gain additional context information.
A System.Drawing.Design.UITypeEditorEditStyle value that indicates the style of editor used by the System.Drawing.Design.UITypeEditor.EditValue(System.IServiceProvider,System.Object) method. If the System.Drawing.Design.UITypeEditor does not support this method, then System.Drawing.Design.UITypeEditor.GetEditStyle will return System.Drawing.Design.UITypeEditorEditStyle.None.
