Aveva.ApplicationFramework.Presentation.Customize Namespace > BoundedTextEditor Class > EditValue Method : EditValue(ITypeDescriptorContext,IServiceProvider,Object) Method
An System.ComponentModel.ITypeDescriptorContext that can be used to gain additional context information.
An System.IServiceProvider that this editor can use to obtain services.
The object to edit.
context
provider
value
The object to edit.
The new value of the object. If the value of the object has not changed, this should return the same object it was passed.
