The zero-based index at which to insert value.
The new value of the element at index.
OnInsertComplete Method
Performs additional custom processes after inserting a new element into the System.Collections.CollectionBase instance.
protected override void OnInsertComplete(
   int index,
   object value
protected:
   int index,
   Object^ value
) override
index
value
