An Integer value representing the zero-based index at which value should be inserted.
A WizardPage object to insert. The value can be null.
Insert Method (WizardPagesCollection)
Inserts an element into the WizardPagesCollection at the specified index.
public void Insert(
   int index,
   WizardPage value
void Insert(
   int index,
   WizardPage^ value
index
value
