AddinManager Class Methods
For a list of all members of this type, see AddinManager members.
![]() | FindAddinFromAssembly | Return addin defined in assembly |
![]() | GetInterfaceAddin | Returns an InterfaceAddin give a name |
![]() | GetInterfaceAddinTty | Returns an InterfaceAddin give a name |
![]() | Load | Loads the Addin defined in the specified assembly |
![]() | LoadAddins | This method will attempt to load all the addins that are defined in the XML file called 'Application.Name'Addins.xml located in the same directory as the application executable. |
![]() | LoadAddinsTty | This method will attempt to load just the tty addins that are defined in the XML file called 'Application.Name'Addins.xml located in the same directory as the application executable. |
![]() | StartAddins | This method iterates through the Addins collection and calls the Start method on each of the addins. |
![]() | StopAddins | This method iterates through the Addins collection and calls the Stop method on each of the addins. |
![]() | Unload | Stop the given Addin and remove it from the Addins collection |
