TaskPaneTool Class Members
The following tables list the members exposed by TaskPaneTool.
Protected Fields
![]() | Control | Gets or sets the control displayed in the TaskPaneTool. NOTE: The Control must also be added to the main windows controls collection. |
Protected Methods
Public Events
![]() | ToolClick | Occurs when the TaskPaneTool is selected. |
