StatusBarPanelsCollection Class Members
The following tables list the members exposed by StatusBarPanelsCollection.
![]() | Item | Indexer which returns an IStatusBarPanel interface for the panel with the given key. |
![]() | AddButtonPanel | Overloaded. Create and add a new StatusBarTextPanel to the collection as a button |
![]() | AddComboEditorPanel | Create and add a new StatusBarTextPanel to the collection as a Combo Editor |
![]() | AddCustomControlPanel | Add a custom Control to the collection Control should be either textbox, combobox or label |
![]() | AddPanelAfter | Add existing panel after an existing key |
![]() | AddPanelBefore | Add existing panel before an existing key |
![]() | AddStateButtonPanel | Overloaded. Create and add a new StatusBarTextPanel to the collection as a state button |
![]() | AddTextPanel | Overloaded. Create and add a new StatusBarTextPanel to the collection |
![]() | ContainsKey | Determines whether the StatusBarPanelsCollection contains a specific key. |
![]() | GetEnumerator | Returns an enumerator that can iterate through the collection. |
![]() | Remove | Remove the panel with the given key from the collection. |
