StateButtonTool Class Members
The following tables list the members exposed by StateButtonTool.
Protected Fields
![]() | Checked | Gets or sets whether the tool is in the checked state. |
![]() | CommandBarDisplayStyle | Gets or sets the style that determines how the StateButtonTool is displayed on an Toolbar or RibbonGroup. |
![]() | CommandChecked | Sets the tool's checked state. |
![]() | MenuDisplayStyle | Gets or sets the style that determines how the image is drawn for the StateButtonTool when the tool is on a PopupMenuTool |
![]() | MenuToolUpdateOptions | Gets or sets how properties of an owning MenuTool will be automatically updated |
![]() | OptionSetKey | Gets or sets the OptionSet key for the tool. Setting the key assigns the tool to the CommandBarManagers OptionSet which has this key. |
![]() | Serializable | Gets or sets a value indicating whether to set the state on restart. |
Protected Methods
Public Events
![]() | ToolClick | Occurs when the tool is clicked. |
