AddPopupContainerTool(String,String,Image,Control,Command,Boolean) Method
Create and add a new PopupContainerTool object to the RootToolsCollection.
- key
- text
- Caption for the tool.
- image
- Icon for the tool.
- control
- Control assigned to the tool.
- command
- Command which the tool is associated with.
- fromXml
- true to from XML.
A PopupContainerTool.
