Aveva.ApplicationFramework.Presentation Namespace > RootToolsCollection Class > AddPopupColorPickerTool Method : AddPopupColorPickerTool(String,String,Image,Command,Boolean) Method
Caption for the tool.
Icon for the tool.
Command which the tool is associated with.
true to from XML.
Create and add a new PopupColorPickerTool object in the RootToolsCollection.
public abstract PopupColorPickerTool AddPopupColorPickerTool(
   string key,
   string text,
   Image image,
   Command command,
   bool fromXml
abstract PopupColorPickerTool^ AddPopupColorPickerTool(
   String^ key,
   String^ text,
   Image^ image,
   Command^ command,
   bool fromXml
key
text
Icon for the tool.
command
fromXml
true to from XML.
A PopupColorPickerTool.
