Arguments for the tool.
true to from XML.
AddListTool(String,String,ArrayList,Boolean) Method
Create and add a new ListTool object in the RootToolsCollection.
public abstract ListTool AddListTool(
   string key,
   string commandId,
   ArrayList arguments,
   bool fromXml
abstract ListTool^ AddListTool(
   String^ key,
   String^ commandId,
   ArrayList^ arguments,
   bool fromXml
key
commandId
arguments
fromXml
true to from XML.
A ListTool.
