Aveva.ApplicationFramework.Presentation Namespace > RootToolsCollection Class > AddContainerTool Method : AddContainerTool(String,String,Control,Command,Boolean) Method
Caption for the tool.
Control assigned to the tool.
Command for the tool.
true to from XML.
Create and add a new ContainerTool object to the RootToolsCollection.
public abstract ContainerTool AddContainerTool(
   string key,
   string text,
   Control control,
   Command command,
   bool fromXml
key
text
control
command
fromXml
true to from XML.
A ContainerTool.
