RootToolsCollection Class Methods
For a list of all members of this type, see RootToolsCollection members.
![]() | AddButtonTool | Overloaded. Create and add a new ButtonTool object to the RootToolsCollection. |
![]() | AddComboBoxTool | Overloaded. Create and add a new ComboBoxTool object to the RootToolsCollection. |
![]() | AddCommandBarMenuTool | Create and add a new CommandBarMenuTool object in the RootToolsCollection. |
![]() | AddContainerTool | Overloaded. Create and add a new ContainerTool object to the RootToolsCollection. |
![]() | AddFontListTool | Overloaded. Create and add a new FontListTool object in the RootToolsCollection. |
![]() | AddLabelTool | Overloaded. Create and add a new LabelTool object to the RootToolsCollection. |
![]() | AddListTool | Overloaded. Create and add a new ListTool object in the RootToolsCollection. |
![]() | AddMdiWindowListTool | Create and add a new MdiWindowListTool object in the RootToolsCollection. |
![]() | AddMenuTool | Overloaded. Create and add a new MenuTool object to the RootToolsCollection. |
![]() | AddPopupColorPickerTool | Overloaded. Create and add a new PopupColorPickerTool object in the RootToolsCollection. |
![]() | AddPopupContainerTool | Overloaded. Create and add a new PopupContainerTool object to the RootToolsCollection. |
![]() | AddPopupGalleryTool | Overloaded. Create and add a new PopupGalleryTool object to the RootToolsCollection. |
![]() | AddStateButtonTool | Overloaded. Create and add a new StateButtonTool object to the RootToolsCollection. |
![]() | AddTaskPaneTool | Create and add a new TaskPaneTool object in the RootToolsCollection. |
![]() | AddTextBoxTool | Overloaded. Create and add a new TextBoxTool object to the RootToolsCollection. |
![]() | Clear | Remove all tools from the RootToolsCollection. |
![]() | Contains | Determine if the tool with the specified Key exists in the RootToolsCollection. |
![]() | GetEnumerator | Returns an enumerator that can iterate through the Collection. |
![]() | Remove | Remove the tool with the specified Key from the RootToolsCollection. |
