RibbonTabGroupsCollection Class Members
The following tables list the members exposed by RibbonTabGroupsCollection.
![]() | Item | Indexer to get the RibbonTabGroup with given Key from the RibbonTabGroupCollection. |
![]() | AddRibbonTabGroup | Create and add to the RibbonTabGroupCollection a new RibbonTabGroup with given Key. |
![]() | Clear | Remove all RibbonTabGroups from the RibbonTabGroupCollection. |
![]() | Contains | Determine if the RibbonTabGroup with the specified Key exists in the RibbonTabGroupCollection. |
![]() | GetEnumerator | Returns an enumerator that can iterate through the RibbonTabGroupCollection. |
![]() | RemoveRibbonTabGroup | Overloaded. Remove the RibbonTabGroup with given Key from the RibbonTabGroupCollection. |
Public Events
![]() | RibbonTabGroupAdded | Occurs after a RibbonTabGroup has been added to the RibbonTabGroupCollection. |
![]() | RibbonTabGroupRemoved | Occurs after a RibbonTabGroup has been removed from the RibbonTabGroupCollection. |
