AddRibbonContextualTabGroup(String,Command,Boolean) Method
            Create and add to the RibbonContextualTabGroupsCollection a new RibbonContextualTabGroup with
            given Key and associated Command.
- key
- The string to test for containment.
- command
- The command.
- fromXml
- true to from XML.
            A RibbonContextualTabGroup.
