Resource identifier for the required Image
Name of resource set to look in
Name of default resource id to use if given resource id is not found
GetImage(String,String,String) Method
Gets a resource Image from the named resource set. Uses defaultResourceId if resourceID is not found
resourceId
resourceSetName
defaultResourceId
