PopupGalleryTool Class Members
The following tables list the members exposed by PopupGalleryTool.
Protected Fields
![]() | Checked | Gets or sets whether the tool is in the checked state. |
![]() | DropDownArrowStyle | Returns or sets the style of the dropdown arrow for the popup menu. |
![]() | Items | Collection of GalleryToolItems contained by this PopupGalleryTool |
![]() | MaxDropDownColumns | Gets or sets the maximum number of columns that can be displayed in the gallery drop down. 0 means there is no limit to the number of columns in the gallery. |
![]() | MaxPreviewColumns | Gets or sets the maximum number of columns that can be displayed in the gallery preview. |
![]() | MinDropDownColumns | Gets or sets the minimum number of columns that can be displayed in the gallery drop down. |
![]() | MinPreviewColumns | Gets or sets the minimum number of columns that can be displayed in the gallery preview. |
![]() | OptionSetKey | Gets or sets the OptionSet key for the tool. Setting the key assigns the tool to the CommandBarManagers OptionSet which has this key. |
![]() | ShowPreviewInRibbon | Gets or sets the value indicating whether the gallery preview should be displayed if this tool is on the ribbon. |
![]() | Tools | Gets the ToolsCollection containing the tools to display in the popup menu. |
![]() | ShowPopup | Displays the PopupGallery as a context popup at the specified point (supplied in screen coordinates). |
Protected Methods
Public Events
![]() | AfterCloseup | Occurs after the menu is displayed |
![]() | AfterPopup | Occurs after the menu is displayed |
![]() | BeforePopup | Occurs before the menu is displayed |
![]() | ToolClick | Occurs when the tool is clicked |
![]() | ToolItemClick | Occurs when a GalleryTool item is clicked |
![]() | ToolItemPreview | Occurs when cursor hovers over a GalleryTool item |
