PopupContainerTool Class Members
The following tables list the members exposed by PopupContainerTool.
Protected Fields
![]() | Control | Gets or sets the control to display in the PopupContainer |
![]() | ClosePopup | Closes the PopupContainer |
![]() | ShowPopup | Shows the PopupContainer |
Protected Methods
Public Events
![]() | AfterCloseup | Occurs after the PopupContainer is displayed |
![]() | AfterPopup | Occurs after the Popup Container is displayed |
![]() | BeforePopup | Occurs before the Popup Container is displayed |
![]() | ToolClick | Occurs then the tool is clicked |
