PopupColorPickerTool Class Properties
For a list of all members of this type, see PopupColorPickerTool members.
![]() | Checked | Gets or sets whether the tool is in the checked state. |
![]() | CommandChecked | Sets the tool's checked state. |
![]() | DropDownArrowStyle | Returns or sets the style of the dropdown arrow for the popup menu. |
![]() | ReplaceableColor | Returns or sets the color in the PopupColorPickerTool's image that will be replaced with the SelectedColor value. Default is Magenta. |
![]() | SelectedColor | Returns/sets the selected color in the PopupColorPickerTool. |
![]() | ShowAutomaticColor | Returns or sets whether a button representing the color Color.WindowText is displayed in the dropdown. |
![]() | ShowTransparentColor | Returns or sets whether a button representing the color Color.Transparent is displayed in the dropdown. |
