MenuTool Class Members
The following tables list the members exposed by MenuTool.
Protected Fields
![]() | AllowTearaway | Gets or sets whether the menu can be torn off |
![]() | AutoUpdate | Gets or sets whether the Image, Tooltip and Command are automatically updated. |
![]() | Checked | Gets or sets whether the tool is in the checked state. |
![]() | CommandChecked | Sets the tool's checked state. |
![]() | Displayed | Gets whether the menu is currently displayed. |
![]() | DropDownArrowStyle | Returns or sets the style of the dropdown arrow for the popup menu. |
![]() | IsContextMenu | Gets or sets whether the menu is a context menu |
![]() | OptionSetKey | Gets or sets the OptionSet key for the tool. Setting the key assigns the tool to the CommandBarManagers OptionSet which has this key. |
![]() | PopupStyle | Gets or sets the popup style of the menu (Menu or CommandBar) |
![]() | SelectedToolKey | Gets or sets the Selected Tools Key |
![]() | Serializable | Gets or sets a value indicating whether to set the state on restart. |
![]() | Tools | Gets the ToolsCollection containing the tools to display in the popup menu. |
![]() | UseLargeImages | Use large images |
![]() | ShowPopup | Overloaded. Displays the MenuTool as a context popup at the current mouse position. |
Protected Methods
Public Events
![]() | AfterCloseup | Occurs after the menu is displayed |
![]() | AfterPopup | Occurs after the menu is displayed |
![]() | BeforePopup | Occurs before the menu is displayed |
![]() | ToolClick | Occurs when the tool is clicked |
