ListTool Class Members
The following tables list the members exposed by ListTool.
Protected Fields
![]() | DisplayCheckmark | Returns or sets whether a checkmark should be displayed next to the selected ListToolItem. |
![]() | SelectedItemIndex | Returns the index of the currently selected ListToolItem. |
![]() | ValueList | Gets the ValueList object associated with the ComboBoxTool. |
Protected Methods
Public Events
![]() | AfterPopup | Occurs after the menu containing the ListTool is displayed |
![]() | BeforePopup | Occurs before the menu containing the ListTool is displayed |
![]() | ToolClick | Occurs when the ButtonTool is clicked. |
