GalleryToolItemCollection Class Members
The following tables list the members exposed by GalleryToolItemCollection.
![]() | Item | Indexer to get the CommandBar with given Key from the CommandBarCollection. |
![]() | Add | Create and add to the GalleryToolItemCollection a new GalleryToolItem with given Name. |
![]() | Clear | Remove all GalleryToolItems from the GalleryToolItemCollection. |
![]() | Contains | Determine if the GalleryToolItem with the specified Key exists in the CommandBarCollection. |
![]() | GetEnumerator | Returns an enumerator that can iterate through the GalleryToolItemCollection. |
![]() | Index | Return index of given GalleryToolItem |
![]() | Remove | Remove the GalleryToolItem with given Key from the GalleryToolItemCollection. |
