FontListTool Class Members
The following tables list the members exposed by FontListTool.
Protected Fields
![]() | FontName | Gets the FontName selected. |
![]() | Width | Gets or sets the width of the tool. |
Protected Methods
Public Events
![]() | AfterCloseup | Occurs after the popup part of the tool is closed. |
![]() | AfterPopup | Occurs after the popup part of the tool is displayed. |
![]() | BeforePopup | Occurs before the popup part of the tool is displayed. |
![]() | ToolClick | Occurs when a font is selected. |
![]() | ToolValueChanged | Occurs when the value of the tool changes. |
