ContainerTool Class Members
The following tables list the members exposed by ContainerTool.
Protected Fields
![]() | Control | Gets or sets the control displayed in the ContainerTool |
![]() | Width | Gets or sets the width of the tool. |
Protected Methods
Public Events
