CommandTypesCollection Class Members
The following tables list the members exposed by CommandTypesCollection.
![]() | Item | Indexer to get the Command with given Key from the CommandCollection. |
![]() | Add | Add the given Command Type to the CommandCollection. |
![]() | ContainsKey | Determine if the Command with the specified Key exists in the CommandCollection. |
![]() | GetEnumerator | Returns an enumerator that can iterate through the CommandBarCollection. |
![]() | Remove | Remove the Command with given Key from the CommandCollection. |
