Sort(IComparer) Method
Sorts the elements in the entire System.Collections.ArrayList using the specified comparer.
public: void Sort( IComparer^ comparer ) override
- comparer
- The System.Collections.IComparer implementation to use when comparing elements.-or- A null reference (Nothing in Visual Basic) to use the System.IComparable implementation of each element.
Exceptions
| Exception | Description |
| System.NotSupportedException | The System.Collections.ArrayList is read-only. |
| System.InvalidOperationException | An error occurred while comparing two elements. |
| System.ArgumentException | a null reference (Nothing in Visual Basic) is passed for comparer, and the elements in the list do not implement System.IComparable. |
