Sort(Int32,Int32,IComparer) Method
Sorts the elements in a range of elements in System.Collections.ArrayList using the specified comparer.
- index
- The zero-based starting index of the range to sort.
- count
- The length of the range to sort.
- comparer
- The System.Collections.IComparer implementation to use when comparing elements.-or- A null reference (Nothing in Visual Basic) to use the System.IComparable implementation of each element.
Exceptions
| Exception | Description |
| System.ArgumentOutOfRangeException | index is less than zero.-or- count is less than zero. |
| System.ArgumentException | index and count do not specify a valid range in the System.Collections.ArrayList. |
| System.NotSupportedException | The System.Collections.ArrayList is read-only. |
| System.InvalidOperationException | An error occurred while comparing two elements. |
