SetRange Method
Copies the elements of a collection over a range of elements in the System.Collections.ArrayList.
public override void SetRange( int index, ICollection c )
public: void SetRange( int index, ICollection^ c ) override
- index
- The zero-based System.Collections.ArrayList index at which to start copying the elements of c.
- c
- The System.Collections.ICollection whose elements to copy to the System.Collections.ArrayList. The collection itself cannot be a null reference (Nothing in Visual Basic), but it can contain elements that are a null reference (Nothing in Visual Basic).
Exceptions
| Exception | Description |
| System.ArgumentOutOfRangeException | index is less than zero.-or- index plus the number of elements in c is greater than System.Collections.ArrayList.Count. |
| System.ArgumentNullException | c is a null reference (Nothing in Visual Basic). |
| System.NotSupportedException | The System.Collections.ArrayList is read-only. |
