Reverse(Int32,Int32) Method
Reverses the order of the elements in the specified range.
- index
- The zero-based starting index of the range to reverse.
- count
- The number of elements in the range to reverse.
Exceptions
| Exception | Description |
| System.ArgumentOutOfRangeException | index is less than zero.-or- count is less than zero. |
| System.ArgumentException | index and count do not denote a valid range of elements in the System.Collections.ArrayList. |
| System.NotSupportedException | The System.Collections.ArrayList is read-only. |
