RemoveRange Method
Removes a range of elements from the System.Collections.ArrayList.
- index
- The zero-based starting index of the range of elements to remove.
- count
- The number of elements to remove.
Exceptions
| Exception | Description |
| System.ArgumentOutOfRangeException | index is less than zero.-or- count is less than zero. |
| System.ArgumentException | index and count do not denote a valid range of elements in the System.Collections.ArrayList. |
| System.NotSupportedException | The System.Collections.ArrayList is read-only.-or- The System.Collections.ArrayList has a fixed size. |
