RemoveAt Method (CommandList)
Removes the element at the specified index of the System.Collections.ArrayList.
- index
- The zero-based index of the element to remove.
Exceptions
| Exception | Description |
| System.ArgumentOutOfRangeException | index is less than zero.-or- index is equal to or greater than System.Collections.ArrayList.Count. |
| System.NotSupportedException | The System.Collections.ArrayList is read-only.-or- The System.Collections.ArrayList has a fixed size. |
