Remove Method (CommandList)
Removes the first occurrence of a specific object from the System.Collections.ArrayList.
- obj
- The System.Object to remove from the System.Collections.ArrayList. The value can be a null reference (Nothing in Visual Basic).
Exceptions
| Exception | Description |
| System.NotSupportedException | The System.Collections.ArrayList is read-only.-or- The System.Collections.ArrayList has a fixed size. |
