InsertRange Method
Inserts the elements of a collection into the System.Collections.ArrayList at the specified index.
public override void InsertRange( int index, ICollection c )
public: void InsertRange( int index, ICollection^ c ) override
- index
- The zero-based index at which the new elements should be inserted.
- c
- The System.Collections.ICollection whose elements should be inserted into the System.Collections.ArrayList. The collection itself cannot be a null reference (Nothing in Visual Basic), but it can contain elements that are a null reference (Nothing in Visual Basic).
Exceptions
| Exception | Description |
| System.ArgumentNullException | c is a null reference (Nothing in Visual Basic). |
| System.ArgumentOutOfRangeException | index is less than zero.-or- index is greater than System.Collections.ArrayList.Count. |
| System.NotSupportedException | The System.Collections.ArrayList is read-only.-or- The System.Collections.ArrayList has a fixed size. |
