Insert Method (CommandList)
Inserts an element into the System.Collections.ArrayList at the specified index.
- index
- The zero-based index at which value should be inserted.
- value
- The System.Object to insert. The value can be a null reference (Nothing in Visual Basic).
Exceptions
| Exception | Description |
| System.ArgumentOutOfRangeException | index is less than zero.-or- index is greater than System.Collections.ArrayList.Count. |
| System.NotSupportedException | The System.Collections.ArrayList is read-only.-or- The System.Collections.ArrayList has a fixed size. |
