Add Method (CommandList)
Adds an object to the end of the System.Collections.ArrayList.
- value
- The System.Object to be added to the end of the System.Collections.ArrayList. The value can be a null reference (Nothing in Visual Basic).
The System.Collections.ArrayList index at which the value has been added.
Exceptions
| Exception | Description |
| System.NotSupportedException | The System.Collections.ArrayList is read-only.-or- The System.Collections.ArrayList has a fixed size. |
