CommandBarsCollection Class Members
The following tables list the members exposed by CommandBarsCollection.
![]() | Item | Indexer to get the CommandBar with given Key from the CommandBarCollection. |
![]() | AddCommandBar | Overloaded. Create and add to the CommandBarCollection a new CommandBar with given Key. |
![]() | AddTaskBar | Create and add a new TaskBar with given Key to the CommandBarCollection. |
![]() | Clear | Remove all CommandBars from the CommandBarCollection. |
![]() | Contains | Determine if the CommandBar with the specified Key exists in the CommandBarCollection. |
![]() | GetEnumerator | Returns an enumerator that can iterate through the CommandBarCollection. |
![]() | RemoveCommandBar | Overloaded. Remove the CommandBar with given Key from the CommandBarCollection. |
Public Events
![]() | CommandBarAdded | Occurs after a CommandBar has been added to the CommandBarCollection. |
![]() | CommandBarRemoved | Occurs after a CommandBar has been removed from the CommandBarCollection. |
