Command Class Methods
For a list of all members of this type, see Command members.
![]() | AttachExecutor | Attaches a CommandExecutor derived class to the command. |
![]() | CancelableExecute | Overloaded. Version of Execute which can be cancelled by an BeforeCommandExecute event handler and which takes arguments. |
![]() | DetachAllExecutors | Detach all CommandExecutor derived classes from the command. |
![]() | DetachExecutor | Detach a CommandExecutor derived class from the command. |
![]() | Execute | Overloaded. The command Execute method which takes arguments, and calls a matching Execute in a derived class. |
![]() | FindExecute | Finds a matching execute overload. |
![]() | GetState | Gets the current state of the command. |
![]() | Refresh | Overloaded. Call to allow the command to update its visibility or enabled state following a change to system. |
![]() | Select | Select the executors (e.g. for Context Tabs) |
![]() | SetProperty | Sets a property. |
