Command Class Properties
For a list of all members of this type, see Command members.
![]() | AllowWaitCursor | Get/Set AllowWaitCusor value. |
![]() | ApplicationContext | Application context for which this command is valid. |
![]() | AttachedExecutorsCount | Get the number of CommandExecutors attached to the command |
![]() | Checked | Gets or sets if the command is in a checked state. Setting this value will set the CommandExecutor.Checked property on all attached CommandExecutors. |
![]() | ContextObjectKey | Key to Context object. |
![]() | Description | Description for the command. |
![]() | Enabled | Gets or sets if the command is enabled. Setting this value will set the CommandExecutor.Enabled property on all attached CommandExecutors. |
![]() | ExecuteOnCheckedChange | Gets or sets a value indicating whether the execute on checked change. |
![]() | Executes | Get all command Execute overloads. |
![]() | IgnoreExecutors | Gets a value indicating whether to ignore executors. |
![]() | Internal | Flag to control the visibility of the command in Customization dialog. |
![]() | IsValid | Gets the IsValid status of the command. A Command may become invalid in some application contexts. |
![]() | Key | The commands key in the CommandCollection. |
![]() | List | ArrayList which can contain data to be presented in the GUI. |
![]() | RunInBackground | Gets or sets a value indicating whether the command should run in background. |
![]() | SelectedIndex | Used to communicate to the command which item in the list was selected. |
![]() | Value | Setting this value will set the CommandExecutor.Value property on all attached CommandExecutors. |
![]() | ValueChanged | True if the value of the command has been changed. |
![]() | Visible | Gets or sets if the command is visible. Setting this value will set the CommandExecutor.Visible property on all attached CommandExecutors. |
