ITool Interface Properties
For a list of all members of this type, see ITool members.
![]() | Arguments | Gets or sets the Attributes of the tool. |
![]() | ButtonGroup | Gets or sets the name of the group the instance tool should be contained within when placed on a RibbonGroup. |
![]() | Caption | Gets or sets the tool caption |
![]() | Category | Gets or sets the tools category |
![]() | DisplayLargeImage | Flag to indicate if a large image should be displayed for an instance of a tool on the ribbon |
![]() | DisplayStyle | Gets or sets the display style for a tool. |
![]() | Enabled | Gets or sets the enabled state of the tool. |
![]() | HelpContextID | Returns or sets the help context identifier used for F1 contextual help. |
![]() | Image | Gets or sets the small image (16x16) displayed on the tool |
![]() | ImageOnly | Flag to indicate if the tool should only display an image and no caption. |
![]() | IsFirstInGroup | Gets or sets a flag which indicated whether an instance tool is the first in a tool group. A separator will be displayed before a tool if this property is set to true. |
![]() | IsXmlDefined | Returns or sets whether tool is xml defined |
![]() | Key | The Key of the tool in the RootToolsCollection |
![]() | KeyTip | Returns or sets a string with a maximum of 3 characters that represents the mnemonic that is displayed when using key tips. |
![]() | LargeImage | Gets or sets the large (32x32) image displayed on the tool |
![]() | List | Sets the List of items used by the tool. |
![]() | Shortcut | Gets or sets the shortcut associated with a tool. |
![]() | SmallImage | Gets or sets the small image (16x16) displayed on the tool |
![]() | Tag | Gets or sets the tag property which can be used to logically attach another object or value to a tool. |
![]() | Tooltip | Gets or sets the tools tooltip |
![]() | TooltipFormattedText | Gets / sets the formatted text to be displayed in the tooltip. |
![]() | TooltipTitle | Gets or sets the text displayed for the tooltip title . |
![]() | Value | Gets or sets the value of the tool. |
![]() | Visible | Gets or sets the visibility of the tool. |
