SizingMode Property (IStatusBarPanel)
Returns or sets how the panel can be sized.
Fixed - The panel's size is controlled by the width.
Automatic - The panel's size is based on its contents.
Adjustable - The panel's base size is controlled by the width but the panel may be resized.
Spring - The panel size is based on the remaining size remaining after the other visible panes have been sized.
PanelSizingMode SizingMode {get; set;}
property PanelSizingMode SizingMode { PanelSizingMode get(); void set ( PanelSizingMode value); }
