Structural Design
Sections
Section Connectivity
: View Section End Connections
Displays the section end connection status for all structural sections in the 3D view.
If the selection is highlighted, check end connections is on.
If the selection is not highlighted, check end connections is off.
The end connection status is highlighted in the 3D view using default colours. The default colours for each connection type can be modified. Refer to
Structural Defaults
for further information. The end connection status is indicated for all sections in the 3D view.
Both ends connected
The sections that are connected at both ends are highlighted in the 3D view.
The default colour is green.
Neither end connected
The sections that are not connected at either end are highlighted in the 3D view.
The default colour is red.
One end connected
The sections that are connected at one end are highlighted in the 3D view. The end that is not connected is indicated.
The default colour is blue.
