Structural Design User Guide
Sections : Section Connectivity : Trim Connected Section Ends
When a connection is modified, the connection manager uses a set of dynamic connectivity rules to trim the attached section to the most appropriate Pline of the owning section. When a section end is trimmed to an alternative Pline the Positioning line lock property of the PLDATU is set to True which stops the connection manager from trimming to a different Pline if further modifications are made.
You are prompted to Pick connected end(s) or Finish
Throughout the section trimming process you can press ESC to cancel the command. Additional functionality is also available.
