Structural Design User Guide
Sections : Section Connectivity : Dynamic Connectivity Rules
If the joint dominance property is False and exceeds the structural connectivity tolerances, the attached section is disconnected and the JLDATU, PLDATU and FIXING elements are deleted. If the attached section does not exceed the structural connectivity tolerances, the connection is maintained and Z distance from the start position is updated.
If the joint dominance property is True, the connection between the owning and attached sections is maintained.
If the start of the owning section is stretched and the joint dominance property is False, the JLDATU position (Z distance from the start position) is modified and the attached section does not change direction.
If the start of the owning section is stretched and the joint dominance property is True, the JLDATU position (Z distance from the start position) is maintained and the attached section changes orientation when reconnected.
If the joint dominance property is False and exceeds the structural connectivity tolerances, the attached section is disconnected and the JLDATU, PLDATU and FIXING elements are deleted. If the attached section does not exceed the structural connectivity tolerances, the connection is maintained and the start distance of the joint is maintained.
